5 members (pauld, Uncles51, 60steve, Jon G, 1 invisible), 92 guests, and 3 robots.
Topics128,203
Posts1,057,286
Members48,467
#950483 06/15/2013 11:44 AM
have a 48 gmc with a 228 single carb Rochester, gas coming out of 3/16 inch hole toward top of carb, had to replace carb gasket, put together, started truck, started coming out, did't have any problems before
Sounds like you may have some debris stuck in your needle valve or the float is leaking causing the needle valve to remain open.
Ed
nobody ever has trouble until .... big_eek something goes wrong
did you check the float level while you had the top off?
have a good fuel filter on the line to the carb?
Check that the float isn't full of gas, the inlet needle valve is in good shape as is the seat and that the float pivot rod is not binding up on the float.
Your fuel pump wasn't touched... right?
I took the top of carb off, bowl was fill to top, float not binding, don't know much about carbs, gave the bottom of top piece a good bath with carb cleaner, letting it dry out, will put together later and try
Shake the float. If you hear sloshing the float needs replaced.
Check the needle and seat while you have it apart. Here's some help
http://chevy.oldcarmanualproject.com/carb/51rochester/index.html
Ed
- Lonnie
My '54 3104
will give it a try, thank you everyone for the help
