3 members (Nick in Manitou, 2 invisible),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,572 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | I have a 1972 C10 with power disc up front
I am looking for some info regarding changing out the rotors from 5x5 to 5x4.75 Don't wanna have to buy a kit if there are options for just changing out the rotors Anyone have suggestions? I gave already changed out to a 4.10 rear end with 4.10 posi which is 5x4.75
Heard about possible van rotors work but not sure.
Thanks for any help
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might be able to use full size Passenger car/Corvette rotors, up to around 1990 (Corvette to '82). No guarantee that they will work, but the full size cars did share bearings and rotors with the 1/2 tons, particularly the Police and Taxi variants. Vans used the same 5x5 bolt pattern as the trucks, as do later full size Passenger.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Should be a machine shop near you that can just drill a 4.75 pattern onto your hub/rotor. Easy to do when staying with the same number of lug bolts, not so easy when going from 6 to 5, 4-5, etc. We do our own but I think the going price would be around $50 a pair. Check with Moser in Portland, IN, I know they do axles so maybe hubs also.
Evan
