4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#949901 06/12/2013 3:26 PM
Does anyone have any info on the Cummins 6AT? I have a line on one but am concerned about fitment in my truck. I know it was built as a replacement for the 292. I've purused the net, but cannot find any dimensions on it. Thanks.
New_Ton #950021 06/12/2013 11:03 PM
Y
Y Offline
I can measure my 6BT or may already have the measurements if it will help I dont know what the AT originally came in. I put it in my '84 K30
Clint Youse
Paris,MO
Yousesteers,
Thank you but the 6AT is a completely different beast from the 6BT. It is a 3.4L straight 6 diesel created by Onan (model L634T). When Cummins bought out Onan, they rebadged the engine as a 6AT. It was designed as a direct replace for the 292. Details are scarce on the web and parts also appear to be scarce and expensive. I have a line on one and think it'd be cool to have a straight 6 diesel in my truck that could actually pull it (compared to the OM617's). Thanks again!
New_Ton #950118 06/13/2013 11:46 AM
N_T;
There are a couple of Onan L634's on ebay. They're in generators. There are pictures and it doesn't look like a "direct replace for a 292". i.e. no side motor mounts and fairly deep block and sump. The one with a turbo is very tall with the turbo mounted high above the valve cover. They look like beasts though.
SimS
P.S.
I have been doing some more research and chatting with another Stovebolter. There IS an automotive/vehicle version of this motor and the OP is correct in that there is a bolt in version of this engine that UPS used to repower it's fleet of Chevy 292 and Ford 300 delivery vans back in the day.
New_Ton #950826 06/17/2013 8:42 AM
Here's an excellent diesel conversion forum, and they have a sub-forum for the 6AT engines.
http://www.4btswaps.com/forum/forum...ariants-Sponsored-by-Proffitt-s-Cruisers
1952 Chevrolet 3800 pickup
---All pictures---
