| | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94989 03/09/2006 3:32 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | I think my tank sender unit is bad but I need to know how to wire the fuel gauge looking at it from the backside of the guage ( 1955 GMC PU ). Does the wire from the Ign on switch go to the Empty side of the fuel gauge or the full side? Thanks Phxamigo
Phxamigo
#94990 03/09/2006 3:48 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My 38 goes to the passenger side of the fuel guage. Without a wiring diagram I'd hook it that way with enough extra wire to reach the other side of the guage if necessary, turn the switch on & see what happens. Make sure you have a good ground to the tank.
#94991 03/09/2006 4:10 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | Thanks for your help Tiny , I'll give it a try & hope it works. If not I'll have to replace the tank sending unit before trying again. Phxamigo
Phxamigo
#94992 03/29/2006 5:08 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | You can go to the Fifth Avenue web site www.fifthaveinternetgarage.com and look up the Runtz and just below the description is the install instructions. Tthe second page of the install instructions is a step by step guide on how to determine if the sender is bad or the dash gauge or the wiring. Print that off and you will know for sure who the bad guy is....Randy | | |
#94993 03/30/2006 1:06 PM | Joined: Dec 2005 Posts: 7 Junior Member | | Junior Member Joined: Dec 2005 Posts: 7 | Thanks for the info Randy, I'll give it a try. Al
Phxamigo
#94994 04/18/2006 5:38 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is a very interesting writeup of the Runtz. Apparently it is not a resistor becuase it is polarity sensitive. That is a nice site too. It is nice to see someone selling parts that they developed themselves. | | |
