| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | I have a bench seat without the adjuster on it, could someone tell me how the wire is routed through the pulleys on the seat frame?? Or is there a diagram out there?
Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It's a single loop around all pulleys, but crisscrosses in the middle. At least that's how my '50 is.
Drew
| | | | | Joined: Mar 2010 Posts: 6 New Guy | | New Guy Joined: Mar 2010 Posts: 6 | Thanks Drew for the info I will give it a try
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I have pics I can dig up of mine when I re-strung the cable. The old one was in place just rusted apart so I was able to reverse engineer it. Let me know...
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | I have the very same issue. If you could get us a photo that would help a ton!
Also, how long is the cable? 12 feet?? I know it is one loop but mine is cut and measures 12 feet and didn't know if any was missing. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Juiannos(sp) seems to be the place for seat belts. Does anyone know the length for a 53 3100? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have the very same issue. If you could get us a photo that would help a ton!
Also, how long is the cable? 12 feet?? I know it is one loop but mine is cut and measures 12 feet and didn't know if any was missing. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=908013 ...click... Contact member Roy Rodgers from the thread above. He might have a drawing | | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | DADS50, thanks for the photos.
Does anyone know how long the cable needs to be?? I need to have one made ASAP.
Thanks | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I thought I had pictures some where, but cannot find them. But looks like you have about as good of pictures as I Thought I had. | | | | | Joined: Feb 2012 Posts: 6 New Guy | | New Guy Joined: Feb 2012 Posts: 6 | Red did you find out how long the cable is? | | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Red did you find out how long the cable is? No, I have not found any further information. I need to ASAP! It's hard to drive the truck without a seat! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I just measured the one I took out of this '48. Roughly 12-1/2 feet. Better start with a 14 foot piece and trim it off.
I always found a milk crate makes a good temp seat. Have to add a pillow when you get old.
| | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | I just measured the one I took out of this '48. Roughly 12-1/2 feet. Thanks Jim for the measurement. Anyone have a photo of how it is routed? | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I just measured the one I took out of this '48. Roughly 12-1/2 feet. Better start with a 14 foot piece and trim it off.
I always found a milk crate makes a good temp seat. Have to add a pillow when you get old. A 5 gallon bucket turned upside down works well also. | | |
