4 members (52Carl, Peggy M, KingG, Cosmo), 68 guests, and 1 robot.
Topics128,022
Posts1,055,387
Members48,422
#948962 06/08/2013 11:51 AM
Ijust got a 65 c10 with a 292. The guage said it was running hot so I put in a mechanical guage to make sure I was getting a correct reading. Sure enough I'm running 210-220 and ocassionally up to 230. I cant find anything wrong with the cooling system. Is there any trick to getting them t run cooler?
DrillANWR #948963 06/08/2013 12:02 PM
Bad thermostat or wrong thermostat
clogged radiator
pghdave1 #949026 06/08/2013 8:20 PM
Does your truck have a radiator shroud?
I'd pull the radiator and have it inspected and then flushed. I'd then reinstall with a new 180 degree thermostat and then fill with water, no antifreeze.
Hopefully that fixes the issue. If it does, then drain half the water and fill back up with antifreeze.
DrillANWR #949033 06/08/2013 9:31 PM
No shroud. Does that make a big difference?
DrillANWR #949573 06/11/2013 11:05 AM
No not a big difference, It makes a HUGE difference.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
DrillANWR #949581 06/11/2013 11:33 AM
As Johntsmith said...you wont believe what a diff it will make. on my 63, I did not have a shroud, but had the 230 inline 6. That was never a problem. After I swapped in a 350 , it over heated in 5 min or less...until I added the shroud, then a consistent 190
DrillANWR #949588 06/11/2013 12:22 PM
awesome. Thanks guys.
DrillANWR #949832 06/12/2013 11:09 AM
It made a MAJOR difference on my '62. I had the 230 and it ran hot, but it got Really Hot after I dropped in the 327. I kept my eyes open and found an original fan shroud on eBay for $25.00.
Some elbow grease and a little paint later and it bolted right in. Now the temp gauge needle sits right in the middle of the gauge. Makes me a happy camper. grin
DrillANWR #949941 06/12/2013 5:40 PM
Yes the shroud will make a difference, also you may check the timming, if it is advanced to much it will run hot.
Tommy
59 apache 1/2t
261 short stepside
