6 members (tclederman, 1955 1 Series, baldeagle, geardaddy, Cosmo, 1 invisible), 70 guests, and 2 robots.
Topics128,015
Posts1,055,335
Members48,419
#94920 03/03/2006 5:48 PM
Hi Folks,
How in the world do you remove the light switch on a 41 Chevy? I can't figure it out. I thought it had a push clip to remove the knob, but I can't find it. The 41 manual show a switch, but it's not like the one in the truck. The switch looks original.
Jeff
#94921 03/03/2006 11:43 PM
There should be a spring-loaded button somewhere on the switch body behind the dash. Push that in and the knob will pull out.
Then remove the retaining nut on the front of the dash.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#94922 03/05/2006 3:22 AM
I’m sitting here holding one in my hand. If your ’41 is like mine you can not see the clip from below . I’ll describe the process for mine.
Probably the easiest way to see it is to loosen the chrome trim ring on the front of the dash and allow the whole switch to roll over upside down. You will see a U” shaped metal tower that houses the dash light dimmer. The rod from the knob passes through this and then it passes though another “U” shaped bracket (facing the opposite direction) which is the slide for the switch itself. The spring clip is inside this second “U” and engages a slot in the rod. Push the spring clip toward the body of the switch and while you have it pushed all the way down into the switch body pull the rod and it will come right out.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#94923 03/06/2006 1:09 AM
Thanks for the help. I will follow the directions and hope for the best.
Jeff
