| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Transplanting a stock/rebuilt 261 into a 37 chev and need info on radiators. Would like to hear from those who have had success in this project. Jury rigged a crossflow radiator for breakin but found using no pressure rad cap and 160 - 180 stats caused boilover. Switched to 7psi cap with 160 stat and no boilover. The 37 rad fill neck does not look like it will accomodate a pressurized cap. What to do ??? Thanks for the help. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the rad itself is in good condition [to stand pressure], you can get a rad shop to change the neck to the one that takes a pressure cap, including a blow-off tube
Bill | | |
