| | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | hey everyone, i havnt posted anything in a while. I finally got my 1958 235 apache up and running again with a newly rebuild motor but my 3 three linkage somehow got tweaked pretty good and when I shift into first it'll grind at first unless you hold the clutch in for 3 seconds and then lightly shift it in. ITS REALLY ANNOYING! Does anyone have a spare set of linkage to a 341 three-speed transmission? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Grinding going into first when stopped has nothing to do with the shift linkage. It is caused by the clutch dragging slightly. Do you have the correct amount of free play in the pedal? If so than I would say to be patient and it will most likely wear in.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 55 | hmm ok, but still my linkage binds up really easy and is sloppy to shift. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sloppy column linkage is usually a problem with the shift box on the lower column and adjustment of the connections on both ends of the rods from that box to the trans Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | !st gear is not synchronized. If you shift to 3rd gear first & then go right into 1st or reverse & will not get the grinding. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
