6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
#949068 06/09/2013 2:32 AM
Can the air pump be removed and air injectiors be pluged and if so what else needs to be done to make engine run right if any thing.
In California any vehicle made prior to 1974 does not require emission control.
Why do you think it is not running right?
Larry
I don't own a vehicle that isn't old enough to drink.
I guess I should have said that the truck does run good now but if I remove pump and injector lines and then plug holes will this do any damage to the engine or cause engine to not run right?
Riding in the Passing Lane
No. It will not hurt it.
1972 Chevy c10 Cheyenne Super
