0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | Ijust got a 65 c10 with a 292. The guage said it was running hot so I put in a mechanical guage to make sure I was getting a correct reading. Sure enough I'm running 210-220 and ocassionally up to 230. I cant find anything wrong with the cooling system. Is there any trick to getting them t run cooler? | | | | | Joined: Apr 2013 Posts: 24 New Guy | | New Guy Joined: Apr 2013 Posts: 24 | Bad thermostat or wrong thermostat clogged radiator | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Does your truck have a radiator shroud?
I'd pull the radiator and have it inspected and then flushed. I'd then reinstall with a new 180 degree thermostat and then fill with water, no antifreeze.
Hopefully that fixes the issue. If it does, then drain half the water and fill back up with antifreeze.
| | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | No shroud. Does that make a big difference? | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | No not a big difference, It makes a HUGE difference.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Aug 2011 Posts: 28 New Guy | | New Guy Joined: Aug 2011 Posts: 28 | As Johntsmith said...you wont believe what a diff it will make. on my 63, I did not have a shroud, but had the 230 inline 6. That was never a problem. After I swapped in a 350 , it over heated in 5 min or less...until I added the shroud, then a consistent 190 | | | | | Joined: Apr 2013 Posts: 7 New Guy | | New Guy Joined: Apr 2013 Posts: 7 | | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | It made a MAJOR difference on my '62. I had the 230 and it ran hot, but it got Really Hot after I dropped in the 327. I kept my eyes open and found an original fan shroud on eBay for $25.00. Some elbow grease and a little paint later and it bolted right in. Now the temp gauge needle sits right in the middle of the gauge. Makes me a happy camper.  | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Yes the shroud will make a difference, also you may check the timming, if it is advanced to much it will run hot.
Tommy 59 apache 1/2t 261 short stepside | | |
