8 members (tclederman, 68ironhead, 3B, GMCJammer51, Otto Skorzeny, Pre '68 Dave, Jon G, 1 invisible),
124
Mod | | | Forums66 Topics128,110 Posts1,056,245 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | I know this topic has gotten a lot of mileage. I know who manufactures the replacement retractors. Everything I can find says to get the manufacturer's part number off the unit you are replacing. I've got the Chevy part number from the assembly manual but can't find a cross reference anywhere. I've seen info on other series but not a TF Burb. My 58 originally came with barn doors that were swapped for the clamshell, so there aren't any parts to pull the info from.
Can anyone provide/confirm the correct model number of the part so I can order replacements from Pullman?
On a related note, does anyone in the Kansas City area know of a shop that can make the cables? They aren't there either.
Larry
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Come on. Someone out there has to have a TF Suburban/Panel with the clam shell doors in it. Please take a look at your retractors and post the manufacturers part number.
Larry
| | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Hey guys, I just bought a 48 suburban with the clam shell doors. It's coming from California so when it gets here I'll look and post the info.
Chevytruckdaddy
Chevytruckdaddy
| | | | | Joined: Aug 2011 Posts: 24 New Guy | | New Guy Joined: Aug 2011 Posts: 24 | Sorry, I haven't been looking here lately. I pulled a retractor out of my 55 TF burb. The part is made by Pullman. It has a part no. of 105-A. Below that are the numbers 9-111B. Hope that this helps. By the way, the strap on mine looks a bit iffy so let me know what you find out.
John | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | John;
Hooah!! Thanks for the info. I'll get a set of replacements form Pullman. Money is tight at the moment so it might be a little while. If I get a big tax refund, maybe I'll be able to convince my wife to let me do a little shopping. :-)
Larry
| | | | | Joined: Mar 2010 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 28 | I know this topic has been discussed before but does anyone have a length on the cables that are in the 55-59 suburbans
I know Larry and I need to get them made.
Thanks!!!
Jon | | | | | Joined: Mar 2010 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 28 |
