Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (Hotrod Lincoln, Youngin' Tut 59, carbking, Cletus1950, ndkid275, Gdads51, 1 invisible), 82 guests, and 4 robots.
Topics128,287
Posts1,058,544
Members48,491
Hi all,
I've been scouring the forums looking for an alternative to recovering my old original bench seat and came across a stovebolter (Julio: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=875241&page=2 )who used a 2000 Dodge Durango 2nd row seat. I stopped by my local Pick-N-Pull a couple of weeks ago and found the exact same seat on a 2000 Durango with no exterior damage and a great interior. Here's the seat mocked up in my truck: http://s1107.photobucket.com/user/52ChevyProject/media/NewSeat1_zps812558be.jpg.html?sort=6&o=36
I went back to the Pick-N-Pull last weekend and pulled the front seat belts and a pair of headrests to use as arm rests:
http://s1107.photobucket.com/user/5...le2_zps4020f9da.jpg.html?sort=6&o=37
The seat cost $45 with center belt and the front belts and headrests cost $34 totaling $79 for an almost new leather seat that is quite comfortable.
My father will be welding up some brackets to mount the seat which sits in the original seat position as well as brackets to mount the 3 point retractable seat belts. The seat leaves enough room on both ends to mount seat belts, plus because they fold forwards, I now have full access to the space behind and below the seat.
Hope this helps anyone looking for a new seat at an affordable price.
Nice score, need pics after finished
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
Moderated by  ndkid275, Phak1
