3 members (Otto Skorzeny, Jeff Ogden, 78buckshot), 45 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#948829 06/07/2013 6:07 PM
hey everyone, i havnt posted anything in a while. I finally got my 1958 235 apache up and running again with a newly rebuild motor but my 3 three linkage somehow got tweaked pretty good and when I shift into first it'll grind at first unless you hold the clutch in for 3 seconds and then lightly shift it in. ITS REALLY ANNOYING! Does anyone have a spare set of linkage to a 341 three-speed transmission?
gbuck #948834 06/07/2013 6:30 PM
Grinding going into first when stopped has nothing to do with the shift linkage. It is caused by the clutch dragging slightly.
Do you have the correct amount of free play in the pedal?
If so than I would say to be patient and it will most likely wear in.
My Blog
gbuck #949125 06/09/2013 12:04 PM
hmm ok, but still my linkage binds up really easy and is sloppy to shift.
gbuck #949127 06/09/2013 12:27 PM
sloppy column linkage is usually a problem with the shift box on the lower column and adjustment of the connections on both ends of the rods from that box to the trans
gbuck #949149 06/09/2013 2:37 PM
Riding in the Passing Lane
!st gear is not synchronized. If you shift to 3rd gear first & then go right into 1st or reverse & will not get the grinding.
1972 Chevy c10 Cheyenne Super
