1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Which is preferred for a stock engine? From what I gather 180 degree was stock, but folks use the 160 degree to have extra protection against boil-over even though it doesn't let the engine run as efficiently. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 160 was the stock rating for most years.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What year 235?
As Bill posted, a 160 degree thermostat was standard on 235s from 1954 up through the late 60s. Some manuals state that 235s went to 170 degree thermostats in 1960/61 when they also supposedly had 13 psi radiator caps (4 psi in 1954 and 7 psi in 1956 and later). I use 160 degree thermostats.
160 degree thermostats became fully open at around 180 degrees.
Most likely a 180 degree thermostat would not be a problem, but it most likely becomes fully open at about 200 degrees.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 180 works good year round if you have a good pressure cap on it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Good information. Thanks! I bought a 160 degree thermostat, so that's the route I think I'll go. | | |
