| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 5 New Guy | | New Guy Joined: May 2013 Posts: 5 | Just got my Title. Trying to figure out the VIN#. I have GBA48698. Doesn't match up with info i get when searching VIN#'s. Anyone got an idea? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Welcome to Stovebolt.com GBA is the prefix on a 1949 216 truck engine code (that page is hard to read) Engine codes were often used for titling/registering vehicles. | | | | | Joined: Oct 2012 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2012 Posts: 58 | My vin# on my 49 is also like that. | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I bought a truck from washington & I too can't figure out where the vin# is. I checked the # on the engine block, the door plate but still not a match. I guess next I will look for a tag on the frame. My vin # is HAD1211222
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | slick, there is no number on the frames before 55 2nd - the number you have is definitely not a 'vin' [body/model identification number], appears closer to an engine number, very possible someone changed the engine and never had the title changed
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Slick69, Where did you find the "vin #"? On a title, registration, or the egnine? Can you post a link to a photo of the code? Might the prefix letters be HBA? If it is the engine serial number (pressed into the block to the rear of the distributor), it looks a little like a 1950 truck engine serial number. If your engine is clean and accessible, find and post the various casting codes, date codes, and engine serial number. A 1950 model truck night have been built in 1949, sold in 1949, and first titled/registered in 1949. Stranger things have been reported. Do you have a Vehicle Serial Number tag between the hinges on the driver's side? | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | The vin# HAD1211222 is on the washington registration. the truck is a 1953 1 ton & so is the registration. I have a bill of sale from the guy I bought it from plus I found the bill of sale from when he bought it. I think I will take the registration to a washington DMV to find out who is on the title & go from there. The engine is a 292 not the original 216. Thanks for the info
