2 members (sron48, Jay R),
96
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94810 02/26/2006 8:14 PM | Joined: Nov 2005 Posts: 16 Junior Member | | Junior Member Joined: Nov 2005 Posts: 16 | Did put a test light on the battery cable and post and started to disconnect fuses to see if the light would go out, but it didnt. The light stayed on without a fuse in the fuse box or a key in the ignition. Now what? Also put a volt meter on the harness that runs down the frame and connects to the tail lights and there is no juice there. Could it be the turn signal switch? Was told it runs tail lights, blinkers, etc. Patrick | | |
#94811 02/26/2006 8:32 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 'd carry on w/ the battery test - pulling fuses showed the accessory circuits are ok, but the battery + also connects to the starter, the ammeter, and voltage regulator [and generator thru the regulator] - pull the big wire off the BATT terminal of the regulator first, which should indicate if the problem is in the charging circuit, if not then it's under the dash
turn switch could affect rear lights, but if you have some function back there, and the front blinkers work, that's not too likely to be causing the battery drain - need to test from the beginning to see where you loose the power to the tail - brakes get their power from the light switch usually, go thru the pedal controlled switch, then to the blinkers where it's a straight thru thing if the blinker's not on - tail lights go from the headlight switch straight to the tail lights, not involved w/ blinkers
Bill | | |
#94812 02/27/2006 11:52 AM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | No Tail Lights or no Stop/Turn lights??? Tail lights DO NOT go through the turn switch. they run from the light switch, to the fire wall connecter, then on to the wire that runs to the back of the truck. Did not any of the info found on my site help? Electrical Demons Tail/Stop Lighting Systems How much Cash do you have? Fill the cab with $100 bills {seat removed}, then ship your truck to me, I'll fix it for you and send it back with the cab emptyed of the $100 bills.  | | |
