| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 62 | I have 1948 1/2 ton original 3 speed on the colum,torque tube.I whant to put a 4 speed in.The 4 speed trans i have is GM 580 474, the i got it from said it came 1949 1/2 ton he whent to S 10 trans, using the same bell housing on his 235.The Ujoint is the same ballcoller is the same input shaft is the same,but the bolt patern is about 1 inch narower left to right on the 4 speed,is there a bellhousing that would make this fit.I do not have ez axses to the inter,so i can not respond.thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Does the 4 speed have a reverse lockout lever on the shifter? If so that is a 1931-47 transmission. 1948 and later 3 and 4 speeds have the same bolt pattern.
See the USA in your vintage Chevrolet! My Blog | | |
