5 members (moparguy, NJC, DadsFirstPickup, Jaison, Nick in Manitou), 90 guests, and 2 robots.
Topics128,137
Posts1,056,747
Members48,454
I have a new harness and it states I need to install a side terminal starter switch on top of the starter. I have moved to 12V also.
Why would I need to do this? I was able to start it up with the regular switch.
the side terminal was the original provision to bypass the ignition resistor while cranking, if you're using an internally resisted 12V coil instead of the ignition resistor you don't need to have the side terminal, if you have an ignition resistor you really should have the bypass provision
Starter Switch with coil-lead side-pole - Classic Parts - about $18
STANDARD MOTOR PRODUCTS Part # SS521 at Rockauto.com - about $15
ECH ST33 at NAPA - about $24
How many folks out there are running 12 volts with external ignition resistor without the side-pole starter switch? Do you ever have trouble starting? Maybe once the ole points start to deteriorate, as they all do over time, it might be nice to have full 12 volts to the points for start-up under this condition. I have a side-pole switch in my shop somewhere. I just haven't taken the time to find it and switch it out. In the meantime, I haven't had any start-up issues without it.
