1 members (VicZ),
231
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 38 | have a 1959 truck i want lowered. Question is what is the best way? and how low can I go before I have to chop it up, which I do not want to. Saw a picture of a truck with a 6.5 rear drop and a 7 front. he said he had original ibeam up in the front, but I dont know. I am looking for 5 inch minimum drop. Help! | | | | | Joined: May 2013 Posts: 12 New Guy | | New Guy Joined: May 2013 Posts: 12 | In the front you can go with a lowered straight axle from cpp or droppedaxles.com. sid is awesome to deal will very helpful. The axle will give you 3 inches plus you can go with a mono leaf or posie springs. The springs will give you another 3 inches. I recommend the posie spri gs I heard the mono leafs are a little rough riding. You will also have to modify your steering arms to prevent bump steer. I also recommend a new tierod with the new style ball joints cpp sells it now. If I missed anything these guys on the forum will let you know. Give sid a call though he will get you set up | | |
