| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2013 Posts: 34 | I'm told my rear spring shackles are worn and should be replaced. (I have a 55.1 model 3100.)
This seems like a reasonable do-it-yourself project, but I can't seem to find all of the job details. The shop manual and the tips here all focus on pulling the old bushings, but what about the threaded pins? If the old shackles were short on grease, will the pins be hard to remove as well as the bushings? If so, how do you get them out?
Do you clean out or polish the inside of the sockets after the bushings are out? How? With what?
Also, does it make sense to grease everything before you reassemble? Or just pump grease into the Zerk's when you're done?
Finally, can you re-use Zerk fittings, or are they cheap enough that you should just go ahead and replace them?
Thanks!
Trooper Jeff If I can't drive my truck, fetch my horse "Courage is saddling up even though you are scared to death" - John Wayne
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The pins should unscrew( is that a word). The bushings should come out with a puller/press. make one out of some threaded rod and an old socket,a piece of pipe and some washers and nuts. You can clean the frame where the bushings go with carb/brake cleaner, it probably won't be that dirty/rusty. A little oil on the bushings before you press them in won't hurt anything and don't reuse the zerks, the new bushings should have new ones. When finished grease the bushings with the wheels off of the ground.
Tommy 59 apache 1/2t 261 short stepside | | |
