2 members (55shaker, Paul_WNC), 75 guests, and 1 robot.
Topics128,035
Posts1,055,552
#94755 02/22/2006 4:23 PM
Junior Member
Junior Member
Have another problem besides the tail lights, I cant keep a charge in the new battery. Put the new one in and cranked her up, checked that still had no tail lights and faint rt blinker, went out this morning and totally dead truck. Battery totally drained again. WTF?
Patrick
#94756 02/22/2006 8:05 PM
Hey, Patrick
I know you put a new alternator in, but it sure sounds like your alternator isn't working correctly. And it also does sound like a grounding problem as others have suggested.
What kind of alternator did you install?
If you're not going all-original with your truck and you want to get your electrical system operating at top efficiency, Click Here and see what I did on my truck -- notice the related links at the bottom of the page, too.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#94757 02/23/2006 6:19 AM
It sounds as though you are just throwing parts at your truck without doing any analysis and without using any diagnostic tools such as a VOM. That is a very expensive method. Disconnect the ground cable at the battery and measure the current with every thing turnd off; should be zero. If not, report back.
#94758 02/25/2006 7:20 PM
Junior Member
Junior Member
Just got the battery recharged and put a vom on it and it read 12.4v but was declining. So had to be altenator...right? Ended up draining the battery so have to take it back in along with alternator to test. Both are new though. SO is voltage reg. Still no tail lights or brake lights. Is the license plate light the ground for the harness? looks to be according to the wiring diagram.
Patrick
#94759 02/25/2006 7:32 PM
ground for the "harness"? things have their own grounds, the harness supplies power - the rear lights all get their ground from their mounting to the bed/frame - might need to add a ground wire from the bed to the frame, which should be the general ground for the truck
if your battery is running down just sitting there w/ nothing on, there's a short someplace, and it doesn't hafta be the alternator - disconnect the ground cable from the batt, put your meter between the neg post and the ground cable, and start disconnecting things until the drain disappears to narrow it down
#94760 02/26/2006 3:32 AM
Junior Member
Junior Member
Did put a test light on the battery cable and post and started to disconnect fuses to see if the light would go out, but it didnt. The light stayed on without a fuse in the fuse box or a key in the ignition. Now what? Also put a volt meter on the harness that runs down the frame and connects to the tail lights and there is no juice there. Could it be the turn signal switch?
Patrick
