Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 95 guests, and 0 robots.
Topics128,274
Posts1,058,433
Members48,490
#946991 05/31/2013 9:20 AM
Hi all,
My truck is a '47 3100 with the original 216. The carb is a Carter W-1 (574s, I think). I've had some carb issues, but am plugging my way through them. One of the things recommended was to confirm float level: done 1/2" seated and ~ 1" "hanging open". After this adjustment, no change in the performance wrt taking choke, so this can be ruled out.
When driving the truck, or just running it, it backfires when I stab the throttle (one pop, relatively light, the wipers jump). Less aggressive throttle application causes no issues.
I'm not prone to think the carb can cause a backfire. What is the best course of investigation? Timing? Overhead re-set?
Thanks for [all] the help.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
BDammers47 #947002 05/31/2013 9:55 AM
I'd start looking for an intake or exhaust manifold leak? Let the motor idle and spray some starter fluid lightly around and see if the idle picks up anywhere.
BDammers47 #947006 05/31/2013 10:53 AM
could be a fuel issue, dumping to much ,,,
seems like most are caused by ignition type, timing,
crack or loose dizz,etc
Redryder pix
My Hotrod
BDammers47 #947059 05/31/2013 2:30 PM
Sounds like a momentary lean situation. The accelerator pump isn't supplying a enough of a squirt of gas to make up for all the air when the butterfly is opened suddenly.
Make sure the piston seal is OK. Make sure the passage from the bowl to the pump bore is not full of gunk. Make sure the one way ball is free and clean. Make sure all of the linkage is adjusted correctly and not worn. 1/16" slop at each linkage point = 1/4" reduced piston stroke and a fraction of a second late piston movement.
BDammers47 #947101 05/31/2013 7:10 PM
I agree with Jim. Although I also had a bad plug, I experienced a similar problem that went away when I rebuilt the carb. And I had a very "weak stream" when I opened the throttle.
BDammers47 #947305 06/01/2013 5:17 PM
Thanks guys.
I will have to concede that rebuilding a carb successfully seems to evade me. I'll get it done by a pro this time.
I'll keep you posted on progress.
BDammers47 #947420 06/02/2013 8:41 AM
Ex Hall Monitor
Ex Hall Monitor
Agree with Jim as well. Pull the top of the filter housing & actuate the throttle linkage. If you don't see a good strong stream of fuel from the accelerator pump you likely found your problem.
