0 members (), 105 guests, and 3 robots.
Topics128,194
Posts1,057,261
Members48,466
have a 1949 chevy 3100 8 lug rims with 6.50 17s. how do i lower and add 6 lug or 5 lug rims??
jeff
Welcome to the forums. If you have 8 lug rims your truck is a 3600 or 3800. Going to 5 or 6 lug axles requires major modification. The HiPo shop is the forum for modified trucks.
can i still put rims and lower it with 8 lugs ?
jeff
With money all things are possible. Try stopping in at local tire and spring shops and see if they can help you out.
Posting this week from the beautiful Rio Grande valley, Texas.
You Tube
You need to check out www.droppedaxles.com. Sid is a good guy and can hook you up with whatever you need. I've got one of his 4" axles in front and his 3" blocks out back.
Yes, you could put 15 inch custom rims or 15 inch steel rims off a later model pickup with some lower profile tires and drop it a bit. I'd stay with a fairly narrow tire on the front though as wider tires could increase the effort to steer the truck in tight quarters.
Sid's http://www.droppedaxles.com/ has a great reputation for doing dropped axles right.
48 Chevy 3100 going back together with a 292 six and AX15 five speed.
I used late model 16 inch steel 8 lug wheels on my 49 Chev PU truck.
Why would you want 6 or 5 lug wheels? 16" with 8x6.5" lug pattern wheels are everywhere and usually cheap if not free
1963 Chevy C30 - 292 I6 +.040" 10.78:1, SM465
1978 GMC K2500
"Four gears with a granny low and six cylinders straight in a row."
