| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94665 02/16/2006 5:59 AM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | Going to convert my 46 to 12V when I install 1956 235. Staying with foot starter. Question: Do I need to use a resistor with the coil? It looks like voltage through resistor is bypassed when starting. How do you accomplish this with the foot starter? I've seen foot starter switches with a side lug, is that what it's for?
You never have enough, til you have too many!
#94666 02/16/2006 6:13 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, the 56 starter should have a terminal on the side of it's switch [a smaller one] that's where the wire to the + on the coil goes - it's hot when the switch is engaged - juice to the coil will normally go thru the key sw, then thru the ign resistor to the coil - when you let off the foot start, the only power the coil can get is thru the resistor
Bill | | |
#94667 02/16/2006 2:50 PM | Joined: Oct 2005 Posts: 41 New Guy | | New Guy Joined: Oct 2005 Posts: 41 | Thanks Bill, Wasn't sure, just wanted to verify.
#94668 02/16/2006 3:55 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | As long as this subject has come up, I have a question too!
If I were to use a coil with an internal resistor, how would I get "full voltage" to the coil when starting. I don't see how this would be possible.
Stuart | | |
#94669 02/16/2006 4:10 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes it's not possible, so if you use a coil that was designed for a later, much superior ignition system, then you have to keep everything working perfectly
the reason the bypass is used is so the coil gets as much "current" as possible when the starter is loading the battery heavily - if everything's tickety it'll fire even tho there's not as fat a spark with the resistance in the circuit
Bill | | |
#94670 02/16/2006 4:29 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bill, Your current post offers much resistance to my way of thinking..but I will accept it with much gratitude, thanks! Stuart | | |
#94671 02/16/2006 8:15 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You bypass the resistor if you are using a coil of around 2.5 Ohms internal resistance. | | |
