| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 1 Junior Member | | Junior Member Joined: May 2003 Posts: 1 | Can anyone confirm that the GMC 228,236,270 engine is based on a Buick design? Also did the pre 39 GMC's (before the cab change) trucks use a Buick engine? Just curious. Thanks! | | |
#9460 05/22/2003 10:26 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | My understanding is that the GMC L6 was a new-from-scratch design, but the engines were built in a former Buick plant. To my knowledge no parts will interchange. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | GMC's brfore and since have used car motors 1938 olds 1956 Pontiac I guess they thought if it was good enought for Chevy pickups to use car engines GMC drivers might not notice. | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | GG,
GMC did use Buick sixes, around 1929-1932 or so.
They also used a Pontiac flat-head six in the light & medium duty trucks of the mid-'30s.
In the '50s, they again used a Pontiac engine -this time a V-8.
I think the '37-'54 sixes were GMC designed and were their own animal; they had insert rod bearings, whereas Buicks kept their beloved poured babbit rods until then end of the straight-8: 1954!
In the late '20s, Buick had the biggest and best valve-in-head sixes of all the GM divisions, so that was probably why they turned there for a new "truck engine".
Will try to come up with more details and get back to you.
Frank McMullen
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
| | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I have limited info on this topic, but my observations are: 1937 - Oldsmobile engine 1938 - Pontiac engine 1939 - 1966 - GMC engines with a smattering of Pontiac thrown in here and there for entertainment after '55. | | | | | Joined: Mar 2003 Posts: 316 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 316 | The 1933 GMC used a Pontiac engine (200 cu.in.) for the first series and the second series used a "Buick type" engine (221 cu.in.). The 1934, 35 and 36 used a Oldsmobile engine (213 cu.in.). The 1937 used the Oldsmobile engine, but it was enlarged to 229 cu.in. The 1938 used the Pontiac engine, which was a 222 cu.in. In 1939, GMC went back to Oldsmobile engine. All engines listed above are for the light duty trucks, 1/2, 3/4 and some 1 ton trucks. This information is acording to "GMC, the first 100 years" by John Gunnell. | | |
