1 members (Phak1),
48
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The top of the carb, where the fitting for the gas line is so worn that the brass fittings screw all the way in without much resistance. Rather than trying to find a new top or replace the carb, can I just JB Weld the brass fitting to the carb? It would seal the threads nicely but is contamination or lasting a problem? Thanks! | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | JB Weld would probably work as long as you never want to remove the fitting again..... Give it plenty of time to cure. Put the epoxy on the threads of the brass piece you are screwing in, so that you don't push the epoxy back into the carb when you screw it in. I don't know if teflon tape (the white tape you wrap on pipe threads) would seal against gas or not.....
John | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Another option would be to install a Heli-Coil in the inlet. Not only would that give you new correct size threads, but they will be far stronger than the original threads, which will eliminate the problems with the stripping out.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Do they make heli-coils for pipe thread?? John | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | After looking at the price for just the tap on eBay I think I would go with the JB Weld.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I see what you mean. Expensive little buggers, aren't they?
Bill Burmeister | | | | | Joined: Apr 2013 Posts: 24 New Guy | | New Guy Joined: Apr 2013 Posts: 24 | I glass bedded a gun years back it came with a brush on coating so the barrel would not stick to the stock is possible to do the same with JB weld when you have parts that need taken apart
Just curious Dave | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | put a fiber or copper washer under the pipe fitting so it seals against the bowl of the carb? | | |
