7 members (1955 1 Series, cmayna, Gray_Ghost, JW51, Pete1946, 55shaker, 1 invisible), 157 guests, and 2 robots.
Topics128,070
Posts1,055,900
Members48,429
#945930 05/26/2013 3:07 PM
Gas Pumper
Gas Pumper
The top of the carb, where the fitting for the gas line is so worn that the brass fittings screw all the way in without much resistance. Rather than trying to find a new top or replace the carb, can I just JB Weld the brass fitting to the carb? It would seal the threads nicely but is contamination or lasting a problem? Thanks!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #945932 05/26/2013 3:20 PM
JB Weld would probably work as long as you never want to remove the fitting again..... Give it plenty of time to cure. Put the epoxy on the threads of the brass piece you are screwing in, so that you don't push the epoxy back into the carb when you screw it in.
I don't know if teflon tape (the white tape you wrap on pipe threads) would seal against gas or not.....
Deve #945949 05/26/2013 5:27 PM
Another option would be to install a Heli-Coil in the inlet. Not only would that give you new correct size threads, but they will be far stronger than the original threads, which will eliminate the problems with the stripping out.
Bill Burmeister
Deve #945976 05/26/2013 8:20 PM
Do they make heli-coils for pipe thread?? John
Deve #945986 05/26/2013 8:54 PM
Yes.
Bill Burmeister
Deve #945991 05/26/2013 9:11 PM
My Blog
Deve #945993 05/26/2013 9:16 PM
After looking at the price for just the tap on eBay I think I would go with the JB Weld.
My Blog
Deve #945998 05/26/2013 9:33 PM
I see what you mean. Expensive little buggers, aren't they?
Bill Burmeister
Deve #946053 05/27/2013 8:06 AM
I glass bedded a gun years back it came with a brush on coating so the barrel would not stick to the stock is possible to do the same with JB weld when you have parts that need taken apart
Just curious Dave
Deve #946212 05/27/2013 9:27 PM
put a fiber or copper washer under the pipe fitting so it seals against the bowl of the carb?
