Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Ridgeback, WICruiser, Joe H), 150 guests, and 7 robots.
Topics128,283
Posts1,058,513
Members48,490
#945637 05/24/2013 9:31 PM
hello everyone, I plan on putting in a 235 engine in my truck, but I was wondering what you all recommend i do about my fuel system. The truck has been sitting for over 15 years, should i take out the gas tank and have it cleaned? What about the fuel lines, should I relace them all? The engine im getting has a good running carb so not worried about that. Thanks.
Hi Matt, A lot depends on what condition the fuel system was left in when it was parked 15 years ago. If old gas was left in the gas tank then it will probably need to be cleaned. I would remove the gas tank from the truck, and shine a flash light (LED ones make great light) and see what the inside looks like. If it has a lot of crap in it, it may need to be taken and cleaned.
I have drained the old gas out of tanks before, where I would need to remove the shutoff on the bottom and actually run a stick up in the tank to get the old gas to run out through the hole. I've then plugged the tank outlet and added lacquer thinner in the tank, which seems to loosen up the old gas varnish. Usually put it in and allow the tank to sit different ways to soak for a few days, then drain. May need to repeat this a couple times to get it nice and clean, according to how much buildup is in the tank.
If there is rust in the tank you may need to get one of those tank sealing kits they sell, follow the directions in the package, usually comes in a three part deal, cleaner, etch and sealer.
Fuel lines can be flushed or replaced. I'd run a replaceable gas filter in the line to start with. It help pick up any debris that might be hiding somewhere.
If the fuel pump is original, if it still works, it probably won't for long after putting it back in service. Probably replace it or rebuild it, you'll be further ahead of things.
If things are very bad at all, you might just be better off to get a new tank, it was well worth the trouble I saved.
Thanks for your helpful advice.
On a 55 truck you should be able to take the sending unit out of the top center and look in the tank to see how it looks without pulling the tank.
My Blog
Thank you Dave.
