3 members (tclederman, Guitplayer, Steelonsteel), 73 guests, and 2 robots.
Topics128,022
Posts1,055,381
Members48,422
#94589 02/12/2006 7:29 PM
Junior Member
Junior Member
I'll be having to replace all of the gauges in the 67. I guess it's best for me to wait until I have the money to buy all the gauges at once, as well as the padded dash piece, since the gauge panel has to come off to access all of this.
My question is this. I have one extra place on the dash to put a gauge, which I assume to be 2 1/16".
Other than the water temperature, battery and oil pressure gauges is there anything I might add in this spot?
Pics of the dash are at the link below, and the spot is in the middle picture next to the steering column.
http://67chevytruck.com/dash.html
Davey
#94590 02/12/2006 9:27 PM
Some of the bigger trucks had a vaccuum gauge that went in that spot. I'm not sure how hard it would be to find a new vaccuum gauge for this, but I suppose it is possible.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#94591 02/12/2006 9:57 PM
If you want to see something expensive, look at one of those clusters with the vacuum gauge and tach. Yikes! There is a restored example on eBay right now - with 2 days to go it's at $468.
1954 GMC De Luxe COE
#94592 02/13/2006 2:05 AM
Junior Member
Junior Member
Hmmm. GMCpanel. I think I'll stick that $468 in my pocket.
I just don't know what's available.
I guess what I'm having to replace will suffice. That's gonna set me back quite a bit. I'll just clean up the blank one and get over it.
Thanks!
Davey
#94593 02/13/2006 2:50 AM
It's not a guage (well maybe a time gauge 8^[ } but, I've read that a clock from an 86 suburban will fit in that spot.
Larry
I don't own a vehicle that isn't old enough to drink.
#94594 02/13/2006 4:07 AM
Junior Member
Junior Member
LGriffin,
A clock. I'll think about that. Good idea.
Davey
#94595 02/14/2006 12:01 AM
Riding in the Passing Lane
How about a tach?
1972 Chevy c10 Cheyenne Super
#94596 02/14/2006 12:48 AM
Junior Member
Junior Member
Quote
Originally posted by Wrenchbender Ret.:
How about a tach?
The truck already has a tach. It doesn't work right either. Got to replace it. It requires a larger hole.
The hole I'm talking about is about 2" diameter. I might consider a vacuum gauge, or leave it "as is".
Money, Money, Money, Money... frown
Thanks!
Davey
#94597 02/14/2006 2:22 AM
Davey - I had a spot like that in my 81 suburban. I put a voltmeter in that spot, it looked pretty good and I was then able to monitor my battery charging. The clock is a good idea. You could put a oil temp gauge there. Got to summitracing.com and cheack out their gauges to get an idea of what you want.
-kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
