1 members (baldeagle), 34 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#945794 05/25/2013 4:55 PM
My new MC has a bleeder screw on the side. Installed and pumped several times and no pressure, help please.
Ridge dweller
ridgeview #945827 05/25/2013 8:50 PM
b10 Offline
Open up the back wheel cylinders and run tubes into containers of brake fluid and keep pumping until bubbles are gone.Close them up .Repeat on the front wheel cylinders .It always worked for me.
ridgeview #945873 05/26/2013 1:16 AM
Bench bleeding should be done on the bench.
ridgeview #945902 05/26/2013 11:32 AM
Agreed. That way you can ensure full travel of the spool.
MNSmith #945999 05/26/2013 9:34 PM
MC Bleed
Try this.....
pull the brake lines off, run a small tube around and back in the fluid, SLOWLY pump the pedal till no more air bubbles are seen. This takes care of the MC, ya still gotta check the wheel cylinders.
Don J wave
1964 Chevy Panel
"The Good Karma Project"
More pix on Photobucket
1957 Chevy Panel
May be goin' to Hell in a bucket, but at least I'm enjoying the ride! ~ Jerry Garcia
ridgeview #946060 05/27/2013 8:43 AM
Ex Hall Monitor
Ex Hall Monitor
I just replaced the master cylinder on my '38. I didn't bench bleed it but it wasn't much of a chore doing it the "normal" way. I've read that a master cylinder will self bleed and that was my experience. We did a standard bleed until we got no more air from the fittings. I had good pedal but by the time I got home after driving home through town I ended up with the best pedal I've ever had on the car. Rock solid with only 1-2" of travel to full lock up.
