3 members (Peggy M, RLB, TUTS 59), 105 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#943985 05/18/2013 1:16 AM
I need to pick up a pair of parking brake cables for a '59 panel. The catalogs list shortbed and longbed, but nothing for a panel. I assume I should use the longbed cables?
thanks
Art
Is rust considered a body style?
The length of the rear cables should be the same for long and short beds, what is different is the front cable.
If you have a Dana 45 rear axle there are no cables offered at the parts places. But they can be special made. Contact Dreamers rods and trucks in everett wa.
arturo, nothing to do with body style, a panel can be long or short frame the same as a pickup, do you have a 1/2T [short frame] panel or a 1T [long frame] panel?
Trucko- not sure which rear end I have. What came stock?
Red, it is a 1/2 ton. Short will work?
yes, you have a short bed ... unfortunately the 59 resto pak is missing the page on the 1/2T rear options, but if it looks like this and is positrac, it's the one referred to
If the cast iron "drop out or 3rd member" comes out its the old style rear end, and all the parts are easy to come by for it, including the park brake cables. If the cast iron is a full housing with the axle tubes pushed in it to make an integral unit, then you have the dana 45 axle, and hard to find parts.
mpg Offline
Wow I have a 59 panel. apache 38 and I have no e brake cable just a lever in the floor going to the driveline brake.
wow? all 1T trucks have the driveline parking brake rather than the drum style
This might be a little off-topic, but 1/2 rear-ends were discussed above: it looks like the 1959 1/2 ton USA Chevrolet trucks had 4 rear-ratios:
3.90:1
3.70:1
3.38:1
3.92:1
The information on the RPOs is missing from the GM Heritage Center truck specifications manual. The manual at the GM website has a little more information than is provided in the specifications manual on the Old Online Chevy Manuals website.
