2 members (Gray_Ghost, 1 invisible),
75
Mod | | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | Are there supposed to be two different block drains on a 1956 235 on the driver's side of the block: one at the back near the bellhousing and one underneath the exhaust manifold outlet? I have what looks like a former drain hole in the rear location that was filled with some sort of filler that wants to weep a little. I have been wondering if I should drill out the filler and tap it for a 1/4" pipe plug or petcock if that's the way it was to begin with.
I found another threaded hole underneath the exhaust manifold outlet with a 3/8" bolt in it. When I took the bolt out coolant gushed out of the hole. Was this hole also to be used for the accelerator pivot (bellcrank) on certain models since it has bolt threads and not pipe threads? (Obviously the bolt needs sealer on it.)
Do the oil holes in the bottom of the rocker arm shafts need to go down when assembling the shafts. That's the way they were before I took them apart to clean them. I just want to make sure this is right. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The rear drain is the only one, As a result of the angle a engine sits the drain area gets plugged up with sediment. You will need to dig that out. It can seem like filler as it can become quite hard. I would be careful about drilling it out as the hole only goes in a short ways then turns up.
The hole at the center is used for the throttle pivot on some application. They are all drilled into the water jacket.
The holes do go down on the shafts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | What is the best way to get the sediment out then without drilling? Can it be chiselled out with a small punch? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I use a small screw driver to dig and twist.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | | | |
