1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
This is probably a stupid question, but I am still kind of a noob when it comes to ignition stuff.
I have a standard points distributor running on 6 volts. Can I use a normal, everyday off-the-shelf tach, or do I need to find a mechanical unit to drop in somewhere (distributor?)
Any advice would be appreciated.
-Brendan
you need a normal off the shelf 6 cyl 6 volt tach - they're made in different flavors and a 12 volt 8cyl tach won't work very well for ya grin
Bill,
Can you really buy a 6 volt tach these days?
Stuart
Wow, you can buy anything these days...the article about the Sun tach brings back memories. You just weren't squat unless you had a Sun tachometer.
As I remember, that shallow tach needed the firewall mounted box with the electronics, but the longer version had all the goodies in the head...I had the shorty...tach that is!
Stuart
Thanks for th info, Guys!
-Brendan
The clock in my 41 Sedan wasn`t working anyways so I came up with the idea to keep the original face and the large hand and mount a tach behind it.
Looks sharp and works great grin
Found one!
Having just shelled out $1000 on a trip I'm taking this summer, I didn't want to spend another $150 on a tach, so I patiently watched ebay and I am now the proud owner of a 6v 6cyl tachometer.
[is stoked]
The best thing is that I'll have a helper next week and that'll be right about the time that it'll get here!
Thanks again for everyone's help!
V
V Offline
I've got one of those units on the firetruck!
photo of "Shorty" firewall mounted transmitter Sun Tach unit: http://community.webshots.com/photo/483681592/1483683384080243953uXWSTP
Sun Tach mounted on pump panel:
http://community.webshots.com/photo/483681592/2876274280080243953gypNHS
I just sent both units in to be restored! They should be back in a couple of weeks.
V
V Offline
BTW: It cost $650 to get both them tach parts restored by Bobs speedometer in Michigan. What you gonna do? I can't leave a hole in the side of the truck.
