1 members (Wooley),
105
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | The car was jacked up today and I noticed maybe 1/4" play on each front wheel when holding the tire at the 12 and 6 oclock position. How do I tell whether it is worn kingpins - or front wheel bearings - or both? Is there a way to pinpoint what is causing the play?
Thanks. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You can be assured that the king pins are loose if you tighten up the spindle nut so that wheel will not spin. If you still have 12-6 movement, that movement is the king pin.
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | That makes sense. Thanks, Tim! | | |
