5 members (UtahYork, Gdads51, Cletus1950, Hotrod Lincoln, MickeyP), 81 guests, and 3 robots.
Topics128,150
Posts1,056,985
Members48,460
The car was jacked up today and I noticed maybe 1/4" play on each front wheel when holding the tire at the 12 and 6 oclock position. How do I tell whether it is worn kingpins - or front wheel bearings - or both? Is there a way to pinpoint what is causing the play?
Thanks.
You can be assured that the king pins are loose if you tighten up the spindle nut so that wheel will not spin. If you still have 12-6 movement, that movement is the king pin.
That makes sense. Thanks, Tim!
