4 members (klhansen, Hotrod Lincoln, 55shaker, UtahYork), 101 guests, and 3 robots.
Topics128,101
Posts1,056,523
Members48,448
Hello, I am hoping someone can tell me what is the easiest replacement for the original steering box (other than a rebuilt OEM steering box).
I see lots of trucks at the shows that have replaced it with more modern replacements. My objective is to have less play in the steering wheel and I think this may help.
Dave
Me and my '53!
Read something about using a Toyota steering box one time. Try searching that. Speedway sells various boxes. And of course, ask at the shows you attend.
Drew
A few questions are in order. Are you after power steering? What are planning for the steering column (the original is part of the box)? What other alterations are you considering (V8, automatic trans)?
If you're just looking to eliminate the play in the steering, overhauling and readjusting the stock box is the easiest way.
Bill Burmeister
No power steering needed. Thanks for the tips
Me and my '53!
I talked to a guy at a cruise night who used a toyota steering box - he seemed pretty talented at fabricating it to make it work. I'd need something that would bolt-in with little modifications.
Me and my '53!
Crusing in the Passing Lane
Hit your local yards, with some rough ideas in mind, be careful, though, different angles, etc., must be accounted for. Buy a used one you think will fit-perhaps none will fit-you might have to modify mount, arms, input, etc., if give up on that one, haven't spent much $. Try again. When happy, get a new or rebuilt one that works.
