11 members (NJC, Otto Skorzeny, KCMongo, JW51, MickeyP, HandyAndy, 32Fordpuchoptop, Steelonsteel, Hotrod Lincoln, 2 invisible), 132 guests, and 3 robots.
Topics128,042
Posts1,055,505
Members48,424
#94551 02/08/2006 10:42 PM
Does anyone have a source for automotive electrical connectors? I am planning to re-wire my 63 C-10 and would like to put some connectors at convenient locations to allow easy removal of various items at a later date...the dash insert is a good example. If I can find the right connectors I can assemble the gauges to the insert and wire it all to a connector on my bench instead of having to stand on my head under the dash trying to solder everything together, and if I need to pull the dash for any reason it will be as simple as unplugging it and taking out a few screws. I thought about re-using the original connectors (such as they are) but would prefer to go with an updated version. Radio Shack carries molex connectors, but they are not really designed for automotive use. Any thoughts are appreciated.
Daily Driver 63 C-10 LWB Fleetside
#94552 02/08/2006 11:04 PM
Waytek wire.
1954 GMC De Luxe COE
#94553 02/08/2006 11:12 PM
GMCPanel...that's exactly what I was looking for. Thanks
#94554 02/09/2006 9:01 AM
No prob.
#94555 02/09/2006 4:08 PM
Apprentice
Apprentice
http://www.madelectrical.com/catalog.shtml
www.delcity.net and www.painlesswiring.com are some others if you want the late model weather pak stuff
