| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Putting together a 61-261 and noticed the head gasket covers 2 coolant holes between the block and head. The original head gasket and 2 new head gaskets I bought have the same holes blocked. The holes are about 3/8 dia and located between #1 and #2 cylinder and #3 and #4 cylinder on the drivers side (not to be confused with the steam holes which are ok.) Seems strange that 2 water passage holes would be cast in the block and head, only to be covered up by a head gasket. Any reasons why? Should I take a hole punch and open these water passages? The edges of the holes will not have the brass edge portection that all other holes have, but for a nonpressurized coolant system I don't think it would matter. | | |
