2 members (Chris's 46 / 515, 2-Ton), 86 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#945319 05/23/2013 6:53 PM
I am attempting to place a new speedometer face and odometer numbers on my 1953 GMC. The old numbers on the odometer just flaked off now I can’t figure out how to realign the odometer so the numbers will move in sequence. Can anyone help.
dcm88 #945333 05/23/2013 8:17 PM
Where did you score the numbers?
I spent a whole day getting a set to print and glue on mine. cry
Sorry, all I remember is it comes apart and goes together right, only one way... and after enough times I figured it out.
Give me ambiguity
or give me something else
CASO #945341 05/23/2013 8:57 PM
Classic Chevy Truck Parts
CASO #945363 05/23/2013 10:01 PM
getting it apart and together again no problem. Getting the numbers to turn in sequence, that's the problem
dcm88 #945409 05/23/2013 11:25 PM
It's not going to help you, but anyone else doing this should make a small scribe mark on the side of each wheel between the 0 and 1. This will serve as a marker to line up the new tape.
To help you, someone who has one apart needs to take pictures showing reference to what number is by the little trigger that turns the next wheel. That should get you closer than the random you have now.
dcm88 #945457 05/24/2013 8:37 AM
- Lonnie
My '54 3104
dcm88 #945473 05/24/2013 9:49 AM
Quote
> See "On to the odometer" in this Tech Tip
- Lonnie
Lonnie,
I followed this Tech Tip to the letter & my rebuild job went without a hitch.
KEY! Follow directions.
The Tech Tip page is a fantistic resource. yahoo
Harold
Harold
dcm88 #945490 05/24/2013 11:27 AM
When doing this, is it a requirement to place the new numbers
exactly as the removed sequence, or is zeroing OK?
Drew
dcm88 #945510 05/24/2013 12:36 PM
you can change the displayed mileage to anything you want, but it needs to be done with the original numbers showing first, not just by pasting the new numbers on at zeros, be a bit frustrating when the first mile traveled caused it to change to 01,111.0 from the previous 90,999.0 wink
dcm88 #945512 05/24/2013 12:40 PM
Is this the same procedure for a 1950? Mine works well, but will be adding new decals, bezel, glass and seal. I would like to use new decals on the odometer...
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Moderated by  ndkid275, Phak1
