1 members (baldeagle),
34
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 69 | Okay guys; Maybe this is a dumb question, but I got my '56 3100 back from the paint shop not long ago and the front bumper doesn't look right. It looks like it is on up-side down. The ends kinda jut-up and it just looks funny. Is it possible to put it on up-side down ? I have studied the way it bolts up and I don't think it could be put on wrong...Please help...I don't know how to post a picture of it...TIA | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Try a google search for your truck - you should get lots of pics to use a comparison. | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I know that it can be done because I did it. My 57 1/2 ton had the bumpers in the bed when I bought it. I just bolted them on and didn't realize that the front was upside down until an older bolter kindly told me about it. As mentioned,checking out a picture should show you the correct way although I've seen a lot of things in the magazines such as fender emblems put on backwards on so called restoration jobs so maybe check out a few sources first. Good luck.
Larry | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | |
