1 members (Samantha),
45
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94517 02/05/2006 2:20 AM | Joined: Nov 2002 Posts: 21 New Guy | | New Guy Joined: Nov 2002 Posts: 21 | I am in the process of rewiring my 57 3100. I put in the new harness and today I installed the new headlight switch. When I hook up the wires, and before I mounted it to the dash, the dash lights work fine with the key in ON or START position, but the dome light does not....when I mount the switch to the dash, the dome light works fine, but now the dash lights are on even when the key is in the off position...Do I have a grounding problem? Any pointers on how to fix this situation? If I leave it as it is, it will drain the battery....Thanks Mike :confused: :confused: | | |
#94518 02/05/2006 3:55 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might be a ground problem - sounds like you may have some wires on the switch wrong - do you have a wiring diagram?
the dome light should get it's power and ground thru the switch, the dash lights get power only from the switch - the wires to both are gray, w/ the dome light being a lighter gauge - maybe you have the 2 wires switched around?
Bill | | |
#94519 02/05/2006 4:20 AM | Joined: Nov 2002 Posts: 21 New Guy | | New Guy Joined: Nov 2002 Posts: 21 | Thanks Bill....I do have a wiring diagram and will double check the wiring again tomorrow... | | |
#94520 02/05/2006 7:58 AM | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Lights should work without the key being on, unless you wired it work that way.
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
#94521 02/05/2006 2:18 PM | Joined: Nov 2002 Posts: 21 New Guy | | New Guy Joined: Nov 2002 Posts: 21 | Paul, agree they should work when the light switch is in the out (ie headlights on) even if the key is off, but mine are on all the time.....unless I turn the knob to the left to turn everything off....I'm going to recheck my wiring today.....
Thanks, Mike | | |
#94522 02/05/2006 8:35 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | New headlight switch...as in repop? If so, throw that POS in the nearest lake and get a good used one. They're available from anyone who sells any used parts. | | |
#94523 02/06/2006 1:26 AM | Joined: Nov 2002 Posts: 21 New Guy | | New Guy Joined: Nov 2002 Posts: 21 | Thanks for the help guys...got it working...very simple....the new knob was too far on the stick, and was preventing the switch from closing when installed..I took the know off, pushed the stick all the way in, reset the knob and now it works fine...except for blowing a fuse when I forgot to turn the key off when I installed it!!!
Appreciate the help!! | | |
#94524 02/06/2006 3:19 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mserges, Isn't it weird how a problem goes from clueless to simple in the blink of an eye! Stuart | | |
