1 members (Phak1),
48
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94514 02/04/2006 12:44 AM | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Hello Everyone, I have a 58 Pu and I am wiring the head lights. I forgot to check before tear down and hope someone can help. When on low beam only the two outside lights are on? High Beam are all four lights on or just the two inside . Thanks for any help!!!!
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
#94515 02/04/2006 1:06 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | low is the outers, high is all 4
Bill | | |
#94516 02/07/2006 12:34 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | hopefully you are installing new low & hi relays into your system do a search and you should have no problem finding what you need... http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001521#000003 http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
