3 members (Rnl364, Oswald, Cosmo), 104 guests, and 3 robots.
Topics128,064
Posts1,055,860
Members48,428
#94514 02/04/2006 12:44 AM
Junior Member
Junior Member
Hello Everyone,
I have a 58 Pu and I am wiring the head lights.
I forgot to check before tear down and hope someone can help.
When on low beam only the two outside lights are on?
High Beam are all four lights on or just the two inside .
Thanks for any help!!!!
Paul
When you do a good deed, get a receipt just incase HEAVEN is
like....the IRS
#94515 02/04/2006 1:06 AM
low is the outers, high is all 4
#94516 02/07/2006 12:34 AM
hopefully you are installing new low & hi relays into your system
do a search and you should have no problem finding what you need...
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001521#000003
Jim & Caroline
