| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 49 | I have a stock 1949 Chevy 3/4 ton truck that is an original daily driver. The wiring is bare in alot of places. Can I install a new wiring harness properly as the truck sits, fully assembled? Who sells the best wiring harness available? Thanks, Dean | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can install a new harness anytime, with a fully functional truck is best cuz you can keep checking as you go, replacing each section as the old is removed .... any of the vendors will have good kits, might not want to go the absolute cheapest, but also no need to spend a bundle, the stock 49 wiring is simple and straight forward
Bill | | | | | Joined: Feb 2013 Posts: 13 New Guy | | New Guy Joined: Feb 2013 Posts: 13 | I just re-wired my '47, got everything I needed from Patricks Antiques. Wires are numbered and come with very good instructions. I went with the stock harness, no problems
1947 AD, 1.5 ton, 216 If you can't fix it with a hammer, you've got an electrical problem! | | | | | Joined: Apr 2013 Posts: 2 Moderated | | Moderated Joined: Apr 2013 Posts: 2 | Hi,if you buy a new old look cloth covered wiring harness they will have a tracer colour running thru them. Maybe yellow with a red tracer or black etc. Sometimes you can pick up the colour from old harness, behind insulation etc. Usually they are well numbered, and theres not that many wires. regards
