Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Bill Hanlon, Otto Skorzeny, Gdads51, Cosmo, MickeyP), 59 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#944859 05/21/2013 6:58 PM
i went to order a radiator and guess what they are out and wont have any for 4 weeks ,, i hat to pay 400 for a brass radiator ,,, geeeeeee
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944879 05/21/2013 8:00 PM
A recore can cost more than that so I think it is a good price.
1951 1 Ton Completed
lilrobo #944888 05/21/2013 8:26 PM
sounds about right.
lilrobo #944902 05/21/2013 10:07 PM
Do you have a good local radiator shop? You should be able to get the original recored for under $400, especially if you go back with a stock core. I had mine done, had a core put in that's good for 600+ horsepower, run me right at $360.
Bill Burmeister
lilrobo #944929 05/21/2013 11:50 PM
I agree with what LongBoxx55 said.. Get it re-cored...!
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
lilrobo #944948 05/22/2013 5:44 AM
I was hoping to get the alum rad for 200 lol
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #944955 05/22/2013 6:47 AM
now you're just talking crazy talk...
lilrobo #945020 05/22/2013 12:48 PM
i been reading that lower the mixture will help my temps ,, i am running 50/50 now distilled water and green anti freeze ,, like i said i been reading that running less anti freeze will help i would have to change it come winter,, but no big deal , what your guys take on this ??
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #945030 05/22/2013 1:08 PM
A 25/75 mix will cool approx 15-20 degrees more than a 50/50 mix... if Cooling is your goal. If your overheating at all this would be an easy help (notice I didn't say "fix")
My recore ran the same as LongBox's.
Give me ambiguity
or give me something else
lilrobo #945031 05/22/2013 1:10 PM
50-50 is what all brands recommend, the "lower mixture" would refer to those who think 80-20 or such gives more freeze protection, straight antifreeze doesn't cool as well .... if you're having heating problems, you need to clean/check over the system, it's not the coolant mix
lilrobo #945052 05/22/2013 3:05 PM
I guess we should clearify the ratio a bit?
80% h2o/ 20% anti freeze will cool better than 50/50 but won't protect from freezing... which I think is why the auto manufacturers recommend the 50/50. It is the optimum minimal for both extremes.
(and still not a 'fix')
Give me ambiguity
lilrobo #945090 05/22/2013 6:04 PM
if you are having heating problems at 50/50, it isn't because you have too much anti freeze.
lilrobo #945093 05/22/2013 6:39 PM
i got my rad back today ,, he said it probably is due to black paint on the fins ,, got me ? , anyway i got a new alum on the way i got it at a discount due to the top tank is discolored ,, i might paint the top and bottom tank anyway and also i got a elect fan too ,, this sucker is going to run cool lol
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #945443 05/24/2013 7:12 AM
Are you looking for a radiator because your engine is overheating, or it is leaking? Is it actually hot? Have you double checked the temp with a known gauge? Does your thermostat work? How hot is it actually getting? If you put an electric fan in front of the radiator it can actually interfere with air flow at highway speeds and contribute to overheating (not necessarily though) You need to look further into this, as a brass radiator actually transfers heat better than an aluminum, although there are other factors involved there. There is no reason to have to add another fan, the original set up is completely adequate for a stock engine, even for a considerably modified engine for that matter. I took my truck through death valley, it never wavered. As far as the black paint, just how much black paint is on it? All the radiator shops I know actually paint them after they do the work on them, but it is a very light coat, and I think it is some special paint.
