1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Well, I'm paying the price for not pulling the tank and cleaning it before I started this project. I have all of the intake valves unstuck except #5 (this thing has a brand new valve job, too). I pulled the tank on Ol' Darrell (58 Apache 32) and it was the most unbelievable, nastiest tank I've ever seen. It looked like a mixture of flaky rust and roofing tar. I tried to wash it out with diesel, and quickly realized that it was too bad for that. I ended up using an extra tank I had from my '59. I did manage to get the fuel gauge sender working again, though. thumbs_up So, take it from me, folks -- Pull that tank and clean it before you try to start a truck with nasty gas. You'll save yourself a lot of trouble, time and money.
There was a car show that showed a guy mixing baking sode and something else ??/ vinegar ?? Anyway, they mixed it in the old tank and swished it around and it seemed to work.
Of course, you can always get a new tank if the rust is too bad.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Oh yes, unless it is an extremely rare tank, just getting a new tank will save you troubles worth way more than the cost of the tank.
Ex Hall Monitor
Ex Hall Monitor
The same experience I had. Maybe it's time to do a Tech Tip?? I acid cleaned then lined the tank on my '38. If a new tank is available it's may be best to replace it.
