5 members (tclederman, DadsFirstPickup, 59 fleet, IHPWR, Ponchogl), 102 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#944451 05/19/2013 11:40 PM
I just finished stripping the parts I need off of a 2003 D60 semi float. My goal is to have a functioning parking brake to go along with the disc setup to put on my early 14 bolt. I'm pleasantly surprised at how simple a setup it is. GM used the same parking brake unit on trucks from 99 on up and 2003 on up vans.
The only thing I'm going to need is to have an axle flange made and weld it to my 14 bolt. Of course, I'll have to come up with something on the brake cables, but all in all, it's looking pretty simple.
The same setup could be used on the Eaton rearends also, with very little fab work.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
As always, we'd love to see some pics of your progress. Keep us posted.
Dave Baird
1951 Chevy 3803
Whitedog #944919 05/21/2013 11:21 PM
Thanks Dave. I intend to post some soon, at least in the near future... LOL! I'm going to check with the Chevy dealer to see if the parts can be sourced individually. The backing plates, brake shoes, spring kit, cables, calipers, and rotors can all be had at your local FLAPS. The only thing missing is the main bracket, and the parking brake lever. The bracket has a Kelsey- Hayes part number, but I haven't been able to source it yet. On a side note, Ford uses a setup that is nearly identical. At one time it was right around $500 a side for the complete kit. They're starting to sell the parts individually now. I have a friend that is the Parts Manager at a Ford dealer, I may give him a visit one of these days.
Anyhow, I'll repost soon.
"The Fake Truck"
Whitedog #945740 05/25/2013 11:55 AM
Well, I did manage to visit the Chevy parts man. He was kind enough to make me a couple explode views of the 2500 van and 2500 Silverado truck rear parking assembly. I need to correct an earlier statement though. I originally thought the van and truck were the same, but it seems there are some slight differences. The biggest difference, is that they use a slightly different caliper. Other than that, everything else is basically the same.
The parking brake bracket, backing plate, bolt kit, rubber boot kit come as assembly. For the 2500 Silverado it's only about $50-$60 per side. Not too shabby. The van is about 3 times that amount. I guess it's a good thing I went the junkyard route. The parking brake lever is $15, which is much cheaper than I expected. The rest of the parts needed are the parking brake shoes, hardware kit, rotors, and calipers. Those are all availible at virtually any parts store. Rockauto seems to have the best prices though.
After all the components are sourced, the only thing really left to do is make and weld on an axle flange. If you have the backing plate in hand, it shouldn't be too hard to figure out. Just trace the holes.
Anyhow, here are the pictures.
http://s1074.photobucket.com/user/w...amp;_suid=136949642785503179884389549961
http://s1074.photobucket.com/user/w...amp;_suid=136949732180303735581118344481
"The Fake Truck"
Whitedog #946296 05/28/2013 10:03 AM
Looking forward to seeing this all together with and a list of part numbers both from GM and the auto parts stores as necessary.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
One thing I didn't do is get the part numbers. Since I already have everything, wasn't too worried. When I went in to see the Chevy parts man, it only took him about 30 seconds to find what I was looking for anyway. The only things that aren't in the pictures above are the rotors, calipers, and brake cables.
I'll take pictures along the way too and maybe post some dimensions of the flange.
"The Fake Truck"
Moderated by  Dusty53
