7 members (TexasJim50, Rusty Rod, thekid1950, baldeagle, Steelonsteel, cmayna, 78buckshot),
54
Mod | | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i went to order a radiator and guess what they are out and wont have any for 4 weeks ,, i hat to pay 400 for a brass radiator ,,, geeeeeee
thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A recore can cost more than that so I think it is a good price. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do you have a good local radiator shop? You should be able to get the original recored for under $400, especially if you go back with a stock core. I had mine done, had a core put in that's good for 600+ horsepower, run me right at $360.
Bill Burmeister | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | I agree with what LongBoxx55 said.. Get it re-cored...! | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | I was hoping to get the alum rad for 200 lol
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | now you're just talking crazy talk... | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i been reading that lower the mixture will help my temps ,, i am running 50/50 now distilled water and green anti freeze ,, like i said i been reading that running less anti freeze will help i would have to change it come winter,, but no big deal , what your guys take on this ??
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | A 25/75 mix will cool approx 15-20 degrees more than a 50/50 mix... if Cooling is your goal. If your overheating at all this would be an easy help (notice I didn't say "fix")
My recore ran the same as LongBox's.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 50-50 is what all brands recommend, the "lower mixture" would refer to those who think 80-20 or such gives more freeze protection, straight antifreeze doesn't cool as well .... if you're having heating problems, you need to clean/check over the system, it's not the coolant mix
Bill | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I guess we should clearify the ratio a bit? 80% h2o/ 20% anti freeze will cool better than 50/50 but won't protect from freezing... which I think is why the auto manufacturers recommend the 50/50. It is the optimum minimal for both extremes. (and still not a 'fix')
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if you are having heating problems at 50/50, it isn't because you have too much anti freeze. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i got my rad back today ,, he said it probably is due to black paint on the fins ,, got me ? , anyway i got a new alum on the way i got it at a discount due to the top tank is discolored ,, i might paint the top and bottom tank anyway and also i got a elect fan too ,, this sucker is going to run cool lol
thanks
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Are you looking for a radiator because your engine is overheating, or it is leaking? Is it actually hot? Have you double checked the temp with a known gauge? Does your thermostat work? How hot is it actually getting? If you put an electric fan in front of the radiator it can actually interfere with air flow at highway speeds and contribute to overheating (not necessarily though) You need to look further into this, as a brass radiator actually transfers heat better than an aluminum, although there are other factors involved there. There is no reason to have to add another fan, the original set up is completely adequate for a stock engine, even for a considerably modified engine for that matter. I took my truck through death valley, it never wavered. As far as the black paint, just how much black paint is on it? All the radiator shops I know actually paint them after they do the work on them, but it is a very light coat, and I think it is some special paint.
