7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible), 105 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#944581 05/20/2013 4:17 PM
have a 48 gmc 1/2ton, but in a 12 volt alternator, pulley alittle more narrow on alt., bottom pulley on motor turns but belt spins around, burning up belt, what to do...
696969 #944588 05/20/2013 4:45 PM
get a wider pulley for the alternator
get a narrower pulley for the balancer
get a belt that splits the width difference and doesn't ride the bottom of the balancer groove
belts come in a wide range of dimensions, they make drive contact on the angled sides, should not be tight to the bottom of the groove, but can be slightly proud of the top when tight
696969 #944596 05/20/2013 5:29 PM
where would I get a wider pulley for alt., can I take off my 6 volt gen. and put on my 12 volt?
696969 #944618 05/20/2013 7:09 PM
alt pulleys are a small diameter, so if the gen one is much bigger, not a good plan - and gen and alt usually have different type shafts, but worth checking out whether it'll work .... otherwise an auto electric shop might have one kicking around, or could try the wreckers
696969 #944619 05/20/2013 7:13 PM
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by 696969
where would I get a wider pulley for alt.?
<CLICK>
696969 #944698 05/21/2013 12:41 AM
I just purchased this one from speedway
...click...
It's cheaper to purchase from their eBay store instead of the web site Shipping is less and no tax for some.
696969 #944713 05/21/2013 5:49 AM
thanks for info guys, will try electric shop first, then ebay... thanks
696969 #944716 05/21/2013 6:41 AM
just make sure you get the right diameter of what ever you get, they aren't all the same and it will mess with water pump/generator speeds. Which may or may not be OK, but the original sizes will be OK for sure.
696969 #944753 05/21/2013 9:30 AM
I solved this problem the hard way on my '52...mainly for ease of future upgrades. I replaced the stock balancer with a two grove (3/8") balancer purchased from Buffalo Enterprises. I also purchased a water pump for a '53 216 (has 3/8" pulley). Now, I am setup for standard modern 3/8" belts for alternator and A/C compressor.
